Disables DSA/RSA X509v3 public key algorithms.
| pk-alg | Specifies disabling DSA/RSA X509v3 public key algorithms. |
| pkalg_name | Specifies which algorithm to disable: "ssh-dss" "ssh-rsa" "x509v3-sign-dss" "x509v3-sign-rsa" |
| all | Specifies disabling all public key algorithms available. |
By default all the algorithms are enabled.
The following example disables the ssh-dss algorithm:
configure ssh2 disable pk-alg ssh-dss
This command was first available in ExtremeXOS 22.3.
